Witam proszę o pomoc w wyjaśnieniu tych błędów kasowałem ale po pewnym czasie ponownie wracają
ewentualnie proszę o wyjaśnienie co i jak zrobić
DIAGNOSTIC REPORT:
VAUX-COM 120309a
Please add your workshop
name in the settings window
**********************ECU ID STARTS**********************
Source Address: CIM
Identifier: 0x0109
VIN: W0L0AHL4858080280
No fault codes stored.
**********************ECU ID ENDS**********************
Source Address: ECM
Identifier: 0x0704
System name: Z17DTL
Number of stored fault codes: 1
P0622 - Generator Field "F" Control Circuit Malfunction
(01) - Present
Source Address: ABS/TC/ESP
Identifier: 0x0401
Source Address: IPC
Identifier: 0x1000
Source Address: AIRBAG SDM
Identifier: 0x0202
Source Address: EHS
Identifier: 0x0402
B1001 - Electronic Control Unit Not Programmed (ECU)
(00) - Present
Source Address: UEC
Identifier: 0x0104
Source Address: REC
Identifier: 0x0105
U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
(00) - Not present
Source Address: ECC
Identifier: 0x0201
B3843 - Air Quality Sensor Circuit Low Voltage
(02) - Present
Source Address: EHU
Identifier: 0x0205
Source Address: DIS
Identifier: 0x1201
